I tried to update Connection Client to version 10.0.19.31 when I received updating reminder. But the updating is failed which cause the Connection Client cannot run. I downloaded Connection Client 10.0.19.31 separately but the software was not able to installed too. The installation process was stopped at the interface below. Installation log is also attached.
CONNECTION_Client_20200902165203.log
Xu Zhile
The log states it is unable to write to the registry. Try running a command window elevated (or powershell elevated) and start the installer from there.
The installer should run that way. If it does not, your company has made it so only someone else can do it for you.
Bill
