Has anyone had any issues running the project validation program for projects done in SS10? I'm trying to run the QC compliance for a project and keep getting this error:
Any help would be greatly appreciated. Thank you!
Yes. Please look at the properties of the shortcut in the target section. Then delete the "Your Arguments" from the Target command and select the apply button. The Project Validator should run with no problems now.
That didn't work. The Target doesn't have "your arguments" in it.
have you tried opening the projectvalidator.exe directly from the location where it's placed from file explorer?
I got it to work. I needed a newer version of the program. Thanks for your response!
