Correct file name for an Aerial dgn file
I am working on a plans submittal where several sheets will require aerials. Generally, I like to create an Aerials.dgn, reference in all the aerial rasters, and then reference that dgn into any drawing where it is needed. The problem, I cannot find a QC compliant file name for my Aerials.dgn.
Is there an appropriate name for a file or this type or is there another procedure I should follow. I'd like to avoid having to reference the rasters into each individual drawing.
  • I typically a file name such as TOPORD99_AERIAL.DGN which passes compliancy.
    Michael S. Donahue
    Kimley-Horn  | 2601 Cattlemen Road, Suite 200, Sarasota, FL 34232
    Direct: 941 379 7602 | Mobile: 941 302 4187
    Connect with us: Twitter|  LinkedIn | Facebook | YouTube
    Proud to be one of FORTUNE magazine’s 100 Best Companies to Work For
    From: zbillin30 [mailto:bounce-zbillin30@communities.bentley.com]
    Sent: Thursday, May 01, 2014 9:44 AM
    To: FDOTElectronicDigitalDelivery@communities.bentley.com
    Subject: [FDOT Electronic/Digital Delivery - Forum] Correct file name for an Aerial dgn file
    View and reply online
    Replying to this email posts your reply in the thread.
  • Yes, Michael is correct. The QC rules are typically triggered on the first six characters of the file name so using TOPORD followed by any other characters will trigger the use of the TOPORD rule file. The only other consideration is to make sure a valid level is active when the images are attached, I recommend using the level ImageAttachment_dp which is intended to be used when placing any images in a DGN file.
  • That sounds good to me. Thanks for the input. I will begin implementing that now.
    Thanks!
    Zachary Billings, P.E.
    Senior Roadway Engineer (Licensed in FL and MI)
    CONSOR Engineers, LLC
    System Info:
    Windows 11 | Intel Core i7-13700k | Nvidia RTX 3080 FTW3 Ultra | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
    ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
    YouTube Page for ORD: https://tinyurl.com/BillingsCADD
  • Actually I had one further questions concerning the location of the actual raster images. I put them in our survey folder and created another folder called Aerials where the sids and sdws are stored. Will this be QC compliant?
    System Info:
  • I use dsgnrd00_Aerial.dgn  which passes compliancy.
