Correct file name for an Aerial dgn file
I am working on a plans submittal where several sheets will require aerials. Generally, I like to create an Aerials.dgn, reference in all the aerial rasters, and then reference that dgn into any drawing where it is needed. The problem, I cannot find a QC compliant file name for my Aerials.dgn.
Is there an appropriate name for a file or this type or is there another procedure I should follow. I'd like to avoid having to reference the rasters into each individual drawing.
  • Yes, you may create sub-directories under any of the discipline folders. You just can't create additional folders in the root of the project.
  • Thanks
    Zachary Billings, P.E.
    Senior Roadway Engineer (Licensed in FL and MI)
    CONSOR Engineers, LLC
    System Info:
    Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
    ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
    YouTube Page for ORD: https://tinyurl.com/BillingsCADD
    Per the CPCHB the data directory is set aside for “project data files, for example material backgrounds for rendering”.  To me, this directory would seem a logical location for support-raster files; however if the aerial imagery is being used as or to supplement survey information, I would think the logical location would be under the survey directory.
    Journaling placement of the raster files is also a good idea.
    Michael S. Donahue
    Kimley-Horn  | 2601 Cattlemen Road, Suite 200, Sarasota, FL 34232
    Direct: 941 379 7602 | Mobile: 941 302 4187
    Connect with us: Twitter|  LinkedIn | Facebook | YouTube
    Proud to be one of FORTUNE magazine’s 100 Best Companies to Work For
    From: zbillin30 [mailto:bounce-zbillin30@communities.bentley.com]
    Sent: Thursday, May 01, 2014 10:54 AM
    To: FDOTElectronicDigitalDelivery@communities.bentley.com
    Subject: RE: [FDOT Electronic/Digital Delivery - Forum] Correct file name for an Aerial dgn file
    View and reply online
    Replying to this email posts your reply in the thread.
    Actually I had one further questions concerning the location of the actual raster images. I put them in our survey folder and created another folder called Aerials where the sids and sdws are stored. Will this be QC compliant?
