Create Existing Ground Profile with a variable Offset from Chain
I would like to use the existing ground profile tool to cut an existing ground for a ditch bottom. The ditch bottom is a variable offset from my CL chain, so I cannot just pick a standard offset.
Is there any way to do this? I want the profile to be able to be plotted on the sheets with my roadway and proposed ditch, so it would need to be along the same CL chain.
This would also apply to existing and proposed utilities as well.
  • Create your ditch profile in the profile view for your CL and project that profile to the horizontal element representing your ditch bottom.
    ~Michael
    http://www.kimley-horn.com/communication/signature/KimleyHorn_LG_LOGO_RGB_PRIMARY_96dpi.jpg
    Michael S. Donahue
    Kimley-Horn  | 1777 Main Street, Suite 200, Sarasota, FL 34236
    Direct: 941 379 7602 | Mobile: 941 302 4187
    Connect with us: Twitter|  LinkedIn | Facebook | YouTube
    Proud to be one of FORTUNE magazine’s 100 Best Companies to Work For
    The electronic files ("Files") furnished by Kimley-Horn to the intended receiver of the Files ("Receiving Party") are provided only for the convenience of Receiving Party and only for its sole use. Receiving Party agrees that it shall be bound by and subject to the terms of this notice.
    For any signed and sealed plans or final deliverables, if there are discrepancies between the Files and the hardcopy of the Files prepared by Kimley-Horn, the hardcopy shall govern. Only printed copies of such documents conveyed by Kimley-Horn may be relied upon.  Any use of these electronic Files will be at the Receiving Party's sole risk.  Receiving Party accepts the Files on an "as is" basis with all faults.
  • I have created my proposed ditch profile based on my CL. What I would like is for my existing ditch profile to also be based up on the CL, so they can both be plotted and compared in the same sheet. I have a chain I created for the CL of the existing ditch. I want to use that as my offset from the Chain for creating an existing profile instead of a single number. Is this even possible?
    Also, this is an older project, so it is SS2. And forgive me for basically just rephrasing the question. I didn't quite understand what you were getting at Michael.
    Zachary Billings, P.E.
    Senior Roadway Engineer (Licensed in FL and MI)
    CONSOR Engineers, LLC
    System Info:
    Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
    ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
    YouTube Page for ORD: https://tinyurl.com/BillingsCADD
  • In both SS2 legacy tools and the new SS3 tools, there is a project profile tool to do what you need.
    Save the existing ground profile for you ditch, ditch_ep, then project it on to the CL profile.
    Vern
  • Thanks Vern, I will check it out
    System Info:
  • Using this method gets me a "Command not defined for this application" message in SS3.
