Corridor lines not showing, still have my template drop lines.
I have been working on this model now for a while and I was working on another part of it. When I can came back to a previous section, I noticed my corridor lines were missing. Not all of my corridor lines though, but just ones for the mainline and a sidestreet. The others i can still see. Also, for the missing corridors, I can still see the template drop lines. The problem is, I can no longer change anything because I need to select a corridor first.
I already tried deleting my GPKRSC files since that seems to be a common theme with SS3, but that did not fix the problem.
  • Sometimes the boundary lines are hard to find. Best to look for the Begin/End tick marks.
    Sometimes the two are on top of one another and others the template boundary can be several feet wider, while the corridor usually hugs the 2D lines.
    In the FDOT workspace the design stage boundaries are complementary and different for the template drops and corridors;
    Preliminary: Gray/White respectively
    Design: Tan/Yellow respectively
    Final: Orange/Red respectively
    Also, use the Project Explorer>Civil Model Tab><design file> to verify the corridors in your file. If you select... then right click on one it will highlight and then you can do most anything from the context menu that displays.
    Vern
    Answer Verified By: Zachary Billings
  • When you made edits to your corridor at a different location, were you drawing in “construction class” mode?  F7 will toggle on/off construction class elements.
    ~Michael
    http://www.kimley-horn.com/communication/signature/KimleyHorn_LG_LOGO_RGB_PRIMARY_96dpi.jpg
    Michael S. Donahue
    Kimley-Horn  | 1777 Main Street, Suite 200, Sarasota, FL 34236
    Direct: 941 379 7602 | Mobile: 941 302 4187
    Connect with us: Twitter|  LinkedIn | Facebook | YouTube
    Proud to be one of FORTUNE magazine’s 100 Best Companies to Work For
    The electronic files ("Files") furnished by Kimley-Horn to the intended receiver of the Files ("Receiving Party") are provided only for the convenience of Receiving Party and only for its sole use. Receiving Party agrees that it shall be bound by and subject to the terms of this notice.
    For any signed and sealed plans or final deliverables, if there are discrepancies between the Files and the hardcopy of the Files prepared by Kimley-Horn, the hardcopy shall govern. Only printed copies of such documents conveyed by Kimley-Horn may be relied upon.  Any use of these electronic Files will be at the Receiving Party's sole risk.  Receiving Party accepts the Files on an "as is" basis with all faults.
  • Vern, Im not sure what it was, but I got them back. I always forget about Project Explorer, but my Corridor was in there. All I did was process corridor. That caused my mainline corridor lines and the sideroad lines to return in the 2D view.
    Also, thanks for the explanation of the colors. I was wondering that as well.
    Mike, my first thought was also construction elements, but I tried toggling that and it just shut all the remaining corridor lines and template drop lines off.
    Thanks guys
    Zachary Billings, P.E.
    Senior Roadway Engineer (Licensed in FL and MI)
    CONSOR Engineers, LLC
    System Info:
    Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
    ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
    YouTube Page for ORD: https://tinyurl.com/BillingsCADD
