I recently switched to the SS4 version, and now when I clip plan sheets, the annotation scale is set to 1:1 (See picture).
This used to default to the scale of the motif file I was clipping from. The annotation scale is causing all of the utilities to show up very small. Is there a fix or setting for changing this besides going sheet by sheet to change after clipping? My border file and motif file are set to 50 scale.
Thank you,
