Turning on the configuration variable when a merging another SURVRD01 file
When I merge one SURVRD01 file into another SURVRD01 file. The SURVRD01 file that is being merged is having its field books dropped. I was told through another source that Bentley has this configuration variable turned off by default. I would like to turn this configuration variable on. However, I do not know the name of this variable or where it is located. Therefore, I would appreciate the help. Thanks.
Sincerely,
Darren Murphy
Civil Drafter
  • In my experience, civil data is excluded when merging one file into another. I was unaware of a variable to enable civil data to be merged, but now that you mention it, I will do some research and see if there is indeed a variable
    Matt Sexton
    CADD Applications Support Coordinator
    Florida Department of Transportation
    Engineering/CADD Systems Office
    850-414-4840
    matt.sexton@dot.state.fl.us
  • Hello Matt,
    One of my coworkers got this question answered by John Hazlip.  Thanks for the quick response and research into it.
    I am forwarding my coworker’s email with John’s response, please see below.
    I how this helps.
    Sincerely,
    Darren Murphy
