I am having an issue where the Quantity Manager Summary Reports dialog box is blank. The Linked Data Manager dialog box shows the XLS quantity files that have been generated and the QM database has items populated but when I go to select a report so that I can import into MicroStation the dialog does not show the reports. See the screen shots.
The system is Windows 10 running PowerGEOPAK 08.11.09.878 with the FDOTSS4 01.03.01.
Please let me know if you have any suggestions.
Sean,
It was great talking to you this morning. Just wanted to document that we determined that either structures or right of way was active on your bar menu, causing LDM to look in the wrong path for the templates. We reconfigured the bar menu/workspace to be Roadway with all standard menu options (with no structures, R/W, or Photogrammetry), and the template options appeared in the LDM dialog.
Please don't hesitate to contact me if you need any assistance in the future.
Kandi
Thanks again Kandi!
