Plan View Labeler results in incorrect station and offset
Hello All,
I've recently cut several roadway plan sheets using motif files following the FDOT workflow pdf without a problem.
However, when I use the plan view labeler to add station/offsets...the station and offset are way off.
I referenced my alignment dgn into a plan sheet just to see if everything checked out, low and behold the plan view is in some arbitrary location...thus explaining the incorrect stations/offsets.
My question is, did I do something wrong or is there a way to fix this?
Thank you!
