I have a question but not sure who i should ask about it in the community world. So i have FDOTSS4 workstation v01.08.00 running on a windows 10 enterprise pro laptop and it's a brand new laptop from HP. One of my engineers uses GEOPAK and Microstation on the computer to do his work. They issue that he is having is that on the computer when he is trying to close a project for the compliance check the computer takes upwards of 4 minutes or more to check and close before he can move on to another document. Another issue would be when he tries to open one of his drawing tools in GEOPAK the program crashes every time.
The engineer also has a windows 7 computer and he does the same exact process on that computer, the compliance check literally takes 2 seconds to check and it's done and he can move on to another project. He also is able to use the drawing tools with no issue at all on the windows 7 computer. So had to switch him back to his windows 7 computer until i get this issue resolved on his new windows 10 computer.
My question, is there a settings on the windows 10 computer that needs changing to allow the program to work more efficiently and not crash? why does it take a long time to load different processes?
I don't know who else to ask on this issues so any help will greatly be appreciated.
Is the Windows 7 computer running FDOTSS4 v01.08.00 also? (or v01.07.00?)
Is the windows 7 computer also running v01.08.00? (or an older version?)
The windows 7 machine is running Microstation v8i and GEOPAK SELECT SERIES 4. It has been running great for some time now on the worker machine. Its only very recently that our company upgraded to windows 10 and CADD support advised me to install FDOTSS4 V01.08.00 on windows 10. Swapped out the windows 7 computer but shortly after windows 10 started giving issue and crashing when operating microstation and geopak from the FDOTSS4 folder. So had to go back to windows 7 so the worker can continue working. So not sure why its working on windows 7 perfectly but not on windows 10.
Crashing and slow operation can be easily solved by running the Workspace Doctor to clean up the Users Temp folder. The Department has been using Windows 10 for several years without issue. As I said before no good can come from sticking to windows 7. Any time the user has an issue with anything from Excel to MicroStation any service desk person will blame it on the operating system and recommend upgrading to 10.
Update your ustnQCInspector.dll file
https://communities.bentley.com/communities/user_communities/fdot_cadd_support/m/fdotss3_-_post_release_fixes/273402
Answer Verified By: Bob Thorburn
