I have a preference file and project file defined.
Upon importing the borehole csv file, I receive an error for all 14 boreholes that they are outside the tin hull.
All are within the project tin, so I'm not sure what is causing the issue. Any help would be appreciated, thanks.
Brett,
I think I can assist. Can you send me your cross section file, GPK, TIN and CSV file? I'll troubleshoot here and see if I can find a solution.
Thanks!
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
Matt,
I emailed you the files.
Thanks for the assistance!
UPDATE
I had to manually enter the bore hole data. Luckily only had 14 to do.
Everything seems to work splendidly from that point.
