Unable to use GEO pak feature
I'm trying to go through one of the training projects from the FDOT CADD training site.
But when opening up function requires input from a gpk file such as Project manager, or DC manager, this prompt appears every time.
Is there a way to fix it?
Thanks.
  • You will need to change the Feature Preferences - Feature Database location associated with the training project to the database on your local PC or server. You can do this by selecting to edit the project, then select preferences, then select feature preferences and then browse to where your database is stored locally. That should do it and you will be good to go.
