Hello all,
I have a couple of users having this error when they try to run a drainage macro in GEOPak: vba interface error unable to run macro 0x80040552. They are using FDOTss4 with geopak. Also, we recently updated Office 16 to 64-bit (not sure if it related). I have also tried to reference the Visual Basic Editor to point to Excel 16. Is there a fix for this?
Thank you in advance.
I'm not sure if this solution also works in SS4. https://communities.bentley.com/communities/user_communities/fdot_cadd_support/f/fdot-cadd-support---geopak-drainage/202733/drainage-structure-vba-error Also see the solution posted here >>> https://communities.bentley.com/communities/user_communities/fdot_cadd_support/f/fdot-cadd-support---geopak-drainage/174216/drainage-vba-error-when-running-draing-vba--drainage-tabulation---update-1-09/619863#619863
colliersengineering.com
I have tried that solution. It still still giving the same error.
I would delete this post and move to the other thread mentioned (you obviously tried w/o success). That way others who have worked through the issue may respond in a specific manner.
You can also reach out to FDOT support email directly. CADD.Support@dot.state.fl.us
Thank you, Shawn, for your suggestions.
