hello ever since we upgraded to a cloud based guidesign license we can not enter project wise with geopak activated. here is the error msg we get.
if i deactivate geopak, i am able to enter the dgn files in project wise.
thanks,
This would be an issue you need to file with Bentley. Sorry, FDOT does not use or or have a way to support ProjectWise configurations.
Was able to figure it out with Transoft (guidesign) and they said the "that error is coming from Haestad module which is used for stormwater management."
two things you can do to fix it is use the Haestad.Support.dll they sent me and place it in: C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\Subsurface
or you can take the subsurface.cfg and temporarily remove it from C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\config\appl
this will allow you get into projectwise dgn's with geopak.
