Hello all.
How can I get my existing fence from my survey to show up when I cut cross sections??
In the image above, I am supposed to be seeing an existing fence line in between the brown slope and the existing ROW on the right side of the road but unfortunately I cannot get it to work.
I have tried copying the fence line from the survey, creating an active profile for it and then adding a feature definition and still I have trouble getting it to show up in my cross section cuts.
However, in my multi-model views, shown below, you can see that the existing fence is showing up in orange in the cross section view in the bottom right.
Any ideas?
TIA
The Feature Definition used doesn't seem to have a XS cell assigned in that portion of its Annotation Group. That may be found in an Element Template being used by that Annotation Group's Annotation Definition. FDOT's XS Annotation Group doesn't appear to have a fence definition in their Annotation Group. Here's the Bentley Learning path if you want to check out how to add a Definition to it... https://learn.bentley.com/app/Public/ViewLearningPathDetails?lpId=111346
colliersengineering.com
Thank you, Shawn. I went into the annotation groups, copied the definition for the Existing ROW and replaced all the ROW parameters with existing fence and boom! Thanks again!
