When I rotate an element with active angle, the rotation holds and when I next place some text, it remembers the angle. Is there a setting to change this behavior or must I set active angle back to 0 degrees every time?
Pat
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
