Hi
When creating txt files for batch process, is there a list of commands that Microstation has available that can be copied into your txt file?
I have created a few simple txt files from key in commands but it has been trial and error to get it to work. Don't know the exact wording to pu in the txt files.
Thanks, John G.
John,
I've done a number of batch processes in Microstation, but it has been a while. The key-in commands are indeed the commands to be used in the command text file, and you can usually find the syntax using the key-in browser. Searching the Microstation Help for "key-in" will return a result with a list of key-in commands. Generally browsing those commands will provide the additional commands that go with them.
If there's something specific that you're trying to achieve, send me an email and I'll be glad to assist in figuring out what commands will best work for your batch process.
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
I had difficulty finding it to. The help document contains "key-in" multiple times, but the section in question can be found by searching for "keyin" without a dash.
I see them, thanks
