Need help working from home with your Bentley software? We're here to help - click here
CADD Compliance - Maintenance Release 8
Good afternoon,
I am running the CADD compliance on a job that was mostly done in MR7 for FDOT SS4. I am now having an issue come up in MR8 that did not happen in MR7. The CADD compliance checker is reporting that TextShNo level is invalid for the planrd rule. I assumed maybe the seed file had changed the level name to something else; however, it is still the same name in a seed file created from MR8. Is this a known issue? What is the proper level for the text sheet number?
Thank you,
