I am new to using MicroStation for FDOT. I've been working on a project that requires 3D modeling of a road, something I've never had to do before. After I created the closed shapes and attempted to clip the terrain. this error box shows up and I'm forced to either clear crash or abort. If anybody has any ideas about what I'm doing wrong, please let me know. (I'm using FDOTSS4, v8i.) Tips, tricks, and advice would also be greatly appreciated.
Thank you for your time!
-Theryn Engle, Engineer Technician, Phillips Precision Engineering
(I apologize for the long strand of code, the embed function isn't working)
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.NullReferenceException: Object reference not set to an instance of an object. at Bentley.Civil.Commands.DTM.PlaceClipDTM.SelectReferenceDTMState.OnPostLocateCheck(ObjectKey objectKey, ObjectKey parentObjectKey, IHitPath hitPath, Nullable`1 point, IViewport viewort) at Bentley.Civil.Geometry.Command.GeometryCommand.ObjectEntryState.OnPostLocateCheck(IHitPath hitPath, Nullable`1 point, IViewport viewort) at Bentley.Civil.UI.Commands.ObjectEntryState.InternalPrimativePickingState.OnPostLocateCheck(IHitPath hitPath, Nullable`1 point, IViewport viewport) at Bentley.Civil.UI.Commands.PickingState.Bentley.Civil.UI.Commands.IPickingState.DoPostLocateCheck(IHitPath hitPath, Nullable`1 point, IViewport viewort) at Bentley.Civil.UI.Commands.PrimitiveCommand.LocateDelegate(IHitPath hitPath, Nullable`1 point, IViewport viewort) at Bentley.Civil.CadSystem.Microstation.MstnLocateManager.OnPostLocate(HitPath* hitPath, ValueType point, MstnViewport viewport) at Bentley.Civil.CadSystem.Microstation.?A0x48eecc73.postLocateFilterFunction(LOCATE_Action locate_Action, msElementUnion* elementP, DgnModelRef* modelRef, UInt32 filePosition, _dPoint3d* pointP, Int32 viewNumber, HitPath* hitPath, SByte* cantAcceptReason) at Bentley.Internal.MicroStation.CoreHook.DispatchNoHandler(UInt32* argStack, UInt32 mysp, IntPtr pFunc) at Bentley.Internal.MicroStation.CoreHook.Dispatch(UInt32* argStack, UInt32 mysp, IntPtr pFunc)
************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9148 (WinRelRS6.050727-9100) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Bentley.PowerPlatform.FeatureAspects Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Bentley.PowerPlatform.FeatureAspects.DLL----------------------------------------msvcm80 Assembly Version: 8.0.50727.9659 Win32 Version: 8.00.50727.9659 CodeBase: file:///C:/WINDOWS/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.9659_none_d08cfd96442b25cc/msvcm80.dll----------------------------------------Bentley.PowerPlatform.FeatureAspects.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PowerPlatform.FeatureAspects.resources.DLL----------------------------------------ustation Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/ustation.DLL----------------------------------------Bentley.General.1.0 Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.General.1.0.DLL----------------------------------------msvcm90 Assembly Version: 9.0.30729.9619 Win32 Version: 9.00.30729.9619 CodeBase: file:///C:/WINDOWS/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9619_none_508d9c7abcbd32b6/msvcm90.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9147 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------Bentley.MicroStation.Interfaces.1.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL----------------------------------------Bentley.MicroStation.XmlObjectModels Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.XmlObjectModels.DLL----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------Microsoft.ApplicationBlocks.ExceptionManagement.1.0 Assembly Version: 1.0.0.0 Win32 Version: 01.00.00.01 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL----------------------------------------Bentley.DialogManager Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DialogManager.DLL----------------------------------------MdlSeed Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/MdlSeed.DLL----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------DetSymbEnabler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/DetSymbEnabler.DLL----------------------------------------Bentley.Designlinks Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.Designlinks.DLL----------------------------------------Bentley.ECObjects.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECObjects.2.0.DLL----------------------------------------Bentley.UI Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.UI.DLL----------------------------------------componentset Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/componentset.DLL----------------------------------------Bentley.ECSystem.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECSystem.2.0.DLL----------------------------------------Bentley.EC.Persistence.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Persistence.2.0.DLL----------------------------------------Bentley.Platform Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Platform.DLL----------------------------------------Bentley.EC.Controls.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Controls.2.0.DLL----------------------------------------Bentley.logging-2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.11.04.09 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.logging-2.0.DLL----------------------------------------Bentley.Exceptions Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Exceptions.DLL----------------------------------------markup Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/markup.DLL----------------------------------------Bentley.MicroStation Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.DLL----------------------------------------Bentley.ECXAttributes Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.ECXAttributes.DLL----------------------------------------Bentley.Geometry.Common.1.0 Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Common.1.0.DLL----------------------------------------mptools Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/mptools.DLL----------------------------------------Bentley.DesignlinksHandler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/Bentley.DesignlinksHandler.DLL----------------------------------------Bentley.Civil.Loader.MicroStation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Loader.MicroStation.3.1.dll----------------------------------------Bentley.Civil.BCSystem.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.3.1.DLL----------------------------------------Bentley.Civil.CadSystem.Interfaces.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Interfaces.3.1.DLL----------------------------------------Bentley.Civil.Objects.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Presentation.3.1.DLL----------------------------------------Bentley.Civil.Objects.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.3.1.DLL----------------------------------------Bentley.Civil.Geometry.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.3.1.DLL----------------------------------------Bentley.Civil.Formatting.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Microstation.3.1.dll----------------------------------------Bentley.PropertyManager Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.PropertyManager.DLL----------------------------------------Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.PropertyEnablers.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Linear.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.3.1.DLL----------------------------------------Bentley.Geometry.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.2.0.DLL----------------------------------------Bentley.MicroStation.Templates.Support Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.Support.DLL----------------------------------------Bentley.MicroStation.WinForms.ECPropertyPane Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL----------------------------------------Bentley.MicroStation.MaterialControl Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.MaterialControl.DLL----------------------------------------Bentley.MicroStation.WinForms.Controls Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL----------------------------------------Bentley.ECObjects.2.0.resources Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.ECObjects.2.0.resources.DLL----------------------------------------System.Runtime.Serialization Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.9140 (WinRelRS6.030729-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll----------------------------------------Bentley.PropertyManager.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PropertyManager.resources.DLL----------------------------------------Bentley.ECXAttributesAddIn Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.ecxattributesaddin.DLL----------------------------------------Microsoft.VisualC Assembly Version: 8.0.0.0 Win32 Version: 8.00.50727.9659 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualC/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll----------------------------------------Bentley.Properties.ElementHandlerPropertiesEnabler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Properties.ElementHandlerPropertiesEnabler.DLL----------------------------------------Bentley.PointCloud Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.PointCloud.DLL----------------------------------------bentley.designexplorer Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.DLL----------------------------------------bentley.designexplorer.elementexplorer Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.elementexplorer.DLL----------------------------------------Bentley.RasterPropertiesEnabler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RasterPropertiesEnabler.DLL----------------------------------------Bentley.PointCloud.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.PointCloud.resources.DLL----------------------------------------Bentley.DesignlinksApp Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.DesignlinksApp.DLL----------------------------------------Bentley.MicroStation.General Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.General.DLL----------------------------------------Bentley.DesignlinksApp.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DesignlinksApp.resources.DLL----------------------------------------kmlplacemark Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/kmlplacemark.DLL----------------------------------------Bentley.PointCloudAdv Assembly Version: 8.11.9.601 Win32 Version: 08.11.09.601 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Descartes/assemblies/Bentley.PointCloudAdv.dll----------------------------------------Bentley.ExpressionEvaluator Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.expressionevaluator.DLL----------------------------------------Bentley.DGNECPlugin Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.DLL----------------------------------------Bentley.DGNECPlugin.Common Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DGNECPlugin.Common.DLL----------------------------------------Bentley.EC.AbstractUI.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.AbstractUI.2.0.DLL----------------------------------------Bentley.ECUISupport Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.ECUISupport.DLL----------------------------------------Bentley.Civil.CadSystem.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.Microstation.3.1.dll----------------------------------------Bentley.Civil.Graphics.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Graphics.3.1.DLL----------------------------------------Bentley.Civil.CadSystem.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CadSystem.3.1.DLL----------------------------------------Bentley.Windowing Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.DLL----------------------------------------Bentley.Civil.Model.MSPlugIn.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.MSPlugIn.3.1.dll----------------------------------------Bentley.Civil.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.3.1.DLL----------------------------------------Bentley.Civil.Objects.RuleManagement.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.3.1.DLL----------------------------------------Bentley.Civil.Objects.Data.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Data.3.1.DLL----------------------------------------Bentley.Civil.MicroStation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MicroStation.3.1.DLL----------------------------------------Bentley.Civil.Microstation.Utils.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.Utils.3.1.DLL----------------------------------------Bentley.Civil.DTM.3.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.393 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.Civil.DTM.3.0.DLL----------------------------------------System.Drawing.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing.Design/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.Design.dll----------------------------------------Bentley.DTM.Element Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/Bentley.DTM.Element.DLL----------------------------------------Bentley.Civil.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.3.1.dll----------------------------------------Bentley.Civil.Applications.GPSTrackExt.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.3.1.dll----------------------------------------Bentley.Interop.MicroStationDGN Assembly Version: 8.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Interop.MicroStationDGN.DLL----------------------------------------Bentley.GlobalPosition Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.GlobalPosition.DLL----------------------------------------Bentley.GeoCoord Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.GeoCoord.DLL----------------------------------------Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.GPSTrackExt.GPSLocalizeSetting.3.1.dll----------------------------------------Bentley.Civil.Applications.Survey.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.3.1.dll----------------------------------------Bentley.Civil.Applications.Survey.Objects.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Objects.3.1.DLL----------------------------------------Bentley.Civil.Applications.Survey.COM.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.COM.3.1.DLL----------------------------------------Bentley.Civil.UI.Commands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Commands.3.1.DLL----------------------------------------Bentley.Civil.UI.Controls.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Controls.3.1.DLL----------------------------------------Bentley.Civil.Objects.UI.Controls.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Controls.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.Accessor.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Accessor.3.1.DLL----------------------------------------Bentley.Civil.DomainModel.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DomainModel.3.1.DLL----------------------------------------Bentley.EC.Presentation.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.EC.Presentation.2.0.DLL----------------------------------------Bentley.Civil.Applications.Survey.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Microstation.3.1.DLL----------------------------------------Bentley.Civil.ProjectSettings.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Model.3.1.DLL----------------------------------------Bentley.Civil.UI.Templates.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.Templates.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.Commands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.Commands.3.1.DLL----------------------------------------Bentley.Civil.Applications.Survey.Settings.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Applications.Survey.Settings.3.1.dll----------------------------------------Bentley.Civil.BCSystem.Base.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.BCSystem.Base.3.1.dll----------------------------------------ElementInfo Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/required/ElementInfo.DLL----------------------------------------Bentley.Civil.Commands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Commands.3.1.dll----------------------------------------Bentley.Civil.Geometry.Command.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Command.3.1.DLL----------------------------------------Bentley.Civil.Model.UI.ContentManagement.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.ContentManagement.3.1.DLL----------------------------------------Bentley.Civil.GraphicalFilters.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Presentation.3.1.DLL----------------------------------------Bentley.Civil.GraphicalFilters.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GraphicalFilters.Model.3.1.DLL----------------------------------------Bentley.Civil.DTM.TextImport.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImport.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Services.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.3.1.DLL----------------------------------------Bentley.Civil.DTM.ImportExport.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImportExport.3.1.DLL----------------------------------------Bentley.Civil.ConsensusModel.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.3.1.dll----------------------------------------Bentley.ECExchange Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ECExchange.DLL----------------------------------------Bentley.DesignSync.DesignViewer Assembly Version: 1.0.0.0 Win32 Version: 01.08.01.18 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DesignViewer.dll----------------------------------------Bentley.DesignSync.Interfaces Assembly Version: 1.0.0.0 Win32 Version: 01.08.01.18 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.Interfaces.DLL----------------------------------------Bentley.DesignSync Assembly Version: 1.0.0.0 Win32 Version: 01.08.01.18 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DesignSync.DLL----------------------------------------Bentley.GeometryStructsNET1 Assembly Version: 3.0.0.0 Win32 Version: 08.33.01.04 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.GeometryStructsNET1.dll----------------------------------------Bentley.DgnPlatformNET Assembly Version: 1.0.0.0 Win32 Version: 01.08.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/DesignSync/Bentley.DgnPlatformNET.dll----------------------------------------Bentley.Civil.ConsensusModel.SDK.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ConsensusModel.SDK.3.1.dll----------------------------------------Bentley.Civil.ContentManagement.Geopak.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.Geopak.2.0.dll----------------------------------------Bentley.Civil.Model.Handlers.ContentManagement.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.ContentManagement.3.1.DLL----------------------------------------Bentley.Civil.ContentManagement.MS.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ContentManagement.MS.3.1.DLL----------------------------------------Bentley.Civil.CoreCommands.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.CoreCommands.3.1.dll----------------------------------------Bentley.Civil.DesignStandards.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DesignStandards.Presentation.3.1.dll----------------------------------------Bentley.Civil.Model.Handlers.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Handlers.3.1.DLL----------------------------------------Bentley.Civil.DTM.Extension.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Extension.3.1.dll----------------------------------------Bentley.Civil.DTM.ImagePP.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.ImagePP.3.1.dll----------------------------------------Bentley.Civil.DTM.LinearGeometry.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.LinearGeometry.3.1.dll----------------------------------------Bentley.Civil.DTM.Services.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.3.1.dll----------------------------------------System.ServiceModel Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.9140 (WinRelRS6.030729-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll----------------------------------------System.Transactions Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll----------------------------------------Bentley.Civil.DTM.Services.Civil.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.Civil.3.1.dll----------------------------------------Bentley.Civil.DTM.Services.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.Services.NUnit.3.1.dll----------------------------------------Bentley.Civil.DTM.TextImportProvider.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTM.TextImportProvider.3.1.dll----------------------------------------Bentley.Civil.DTMGraphicalFilters.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Model.3.1.dll----------------------------------------Bentley.Civil.DTMGraphicalFilters.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.DTMGraphicalFilters.Presentation.3.1.dll----------------------------------------Bentley.Civil.EditTM.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.EditTM.3.1.dll----------------------------------------Bentley.Civil.Formatting.Microstation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Formatting.Microstation.3.1.dll----------------------------------------Bentley.Civil.Geometry.Coordinates.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Coordinates.3.1.dll----------------------------------------Bentley.Civil.Geometry.DesignStandards.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.DesignStandards.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ComplexConstructions.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Linear.ECXML.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.ECXML.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.NUnit.3.1.dll----------------------------------------Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Linear.UnitTestAssistant.3.1.dll----------------------------------------Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.MicroStation.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Model.ContentManagement.Management.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.ContentManagement.Management.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Model.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Geometry.Model.SnapRules.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Model.SnapRules.3.1.dll----------------------------------------Bentley.Civil.Geometry.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Presentation.3.1.dll----------------------------------------Bentley.Civil.Model.UI.Geometry.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.UI.Geometry.3.1.DLL----------------------------------------Bentley.Civil.Geometry.Services.Civil.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.Civil.3.1.dll----------------------------------------Bentley.Civil.Geometry.Services.GEOPAK.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.GEOPAK.2.0.dll----------------------------------------Bentley.Civil.Geometry.Services.LandXML.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.Services.LandXML.3.1.dll----------------------------------------Bentley.Civil.Geometry.VCAdapter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geometry.VCAdapter.3.1.dll----------------------------------------Bentley.Civil.Geopak.Services.Geometry.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.2.0.dll----------------------------------------Bentley.Civil.Geopak.Services.Geometry.Local.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Geopak.Services.Geometry.Local.2.0.dll----------------------------------------Bentley.Civil.GPSTrackExtCom.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.GPSTrackExtCom.3.1.dll----------------------------------------Bentley.Civil.Help.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Help.3.1.dll----------------------------------------Bentley.Civil.MessageCenter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MessageCenter.3.1.dll----------------------------------------Bentley.Civil.Microstation.TestUtils.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Microstation.TestUtils.3.1.dll----------------------------------------Bentley.Civil.Model.Tools.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Model.Tools.3.1.dll----------------------------------------Bentley.Civil.MSNUnit.ECXML.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MSNUnit.ECXML.3.1.dll----------------------------------------Bentley.Civil.MX.Survey.XINCreator.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.MX.Survey.XINCreator.3.1.dll----------------------------------------Bentley.Civil.Objects.Engine.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.NUnit.3.1.dll----------------------------------------Bentley.Civil.Objects.Engine.Nunit.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Engine.Nunit.Model.3.1.dll----------------------------------------Bentley.Civil.Objects.RuleManagement.Logger.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.Logger.3.1.dll----------------------------------------Bentley.Civil.Objects.RuleManagement.NUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.3.1.dll----------------------------------------Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.RuleManagement.NUnit.Model.3.1.dll----------------------------------------Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.Rulemanagement.NUNit.MSPlugIn.3.1.dll----------------------------------------Bentley.Civil.Objects.UI.Coordinates.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.Coordinates.3.1.dll----------------------------------------Bentley.Civil.Objects.UI.EntryTests.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Objects.UI.EntryTests.3.1.dll----------------------------------------Bentley.Civil.Preferences.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Preferences.3.1.dll----------------------------------------Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProductDrivers.Geopak.VCAdapter.2.0.dll----------------------------------------Bentley.Civil.ProjectSettings.Presentation.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.ProjectSettings.Presentation.3.1.dll----------------------------------------Bentley.Civil.RoadwayDesigner.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.RoadwayDesigner.3.1.dll----------------------------------------Bentley.Civil.Solids.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.3.1.dll----------------------------------------Bentley.Civil.Solids.PlugIn.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.PlugIn.3.1.dll----------------------------------------Bentley.Civil.Solids.Plugin.MSNUnit.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Solids.Plugin.MSNUnit.3.1.dll----------------------------------------Bentley.Civil.Surface.DemToDtm.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Surface.DemToDtm.3.1.dll----------------------------------------Bentley.Civil.UI.CursorPrompt.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.CursorPrompt.3.1.DLL----------------------------------------Bentley.Civil.UI.ControlBinders.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.UI.ControlBinders.3.1.dll----------------------------------------System.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll----------------------------------------Bentley.Civil.Visualisation.Exporter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Bentley.Civil.Visualisation.Exporter.3.1.dll----------------------------------------Bentley.Civil.RoadwayDesigner Assembly Version: 3.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/RoadwayDesign/bin/plugins/Bentley.Civil.RoadwayDesigner.DLL----------------------------------------Bentley.Civil.Commands.CivilFilter.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/CivilPlatform/Filters/Bentley.Civil.Commands.CivilFilter.3.1.dll----------------------------------------Bentley.Civil.DTM.Services.MX.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.DTM.Services.MX.2.0.dll----------------------------------------Bentley.Civil.Geometry.Services.MX.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.Geometry.Services.MX.2.0.dll----------------------------------------Bentley.Civil.MX.ModelFile.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.ModelFile.2.0.DLL----------------------------------------Bentley.Civil.MX.Interop.MXDrainage Assembly Version: 1.7.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.MXDrainage.dll----------------------------------------Bentley.Civil.MX.Interop.StdType Assembly Version: 2.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.StdType.dll----------------------------------------Bentley.Civil.MX.Interop.VBA Assembly Version: 6.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Interop.VBA.dll----------------------------------------Bentley.Civil.MX.StyleSetReader.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.StyleSetReader.2.0.dll----------------------------------------Bentley.Civil.MX.Surface.2.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/MX/Bentley.Civil.MX.Surface.2.0.dll----------------------------------------AxSHDocVw Assembly Version: 1.1.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/AxSHDocVw.DLL----------------------------------------SHDocVw Assembly Version: 1.1.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/SHDocVw.DLL----------------------------------------Bentley.Bedrock.Redistributable Assembly Version: 1.0.3152.28781 Win32 Version: 1.0.3152.28781 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Bedrock.Redistributable.DLL----------------------------------------System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll----------------------------------------Bentley.Civil.Geometry.Utilities.ClashDetection Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Geometry.Utilities.ClashDetection.dll----------------------------------------Bentley.Civil.Geometry.Utilities.Drawing Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Geometry.Utilities.Drawing.DLL----------------------------------------Bentley.Civil.Subsurface Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Civil.Subsurface.dll----------------------------------------System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------Bentley.Hyd.CatalogServices Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CatalogServices.dll----------------------------------------System.Core Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.9135 built by: WinRelRS6 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll----------------------------------------Bentley.Hyd.CatalogServices.Model Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CatalogServices.Model.dll----------------------------------------Bentley.Hyd.CP.Core Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CP.Core.dll----------------------------------------Haestad.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DLL----------------------------------------Haestad.Framework Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.DLL----------------------------------------Haestad.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.DLL----------------------------------------Haestad.Drawing.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.Domain.DLL----------------------------------------Haestad.Mapping Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Mapping.DLL----------------------------------------Bentley.Hyd.CP Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.CP.dll----------------------------------------Haestad.Drawing.Control Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.Control.DLL----------------------------------------Haestad.LicensingFacade Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LicensingFacade.DLL----------------------------------------Haestad.Framework.Windows.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.DLL----------------------------------------Haestad.MicroStation.Support.ViewAttributesDialogAddon Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MicroStation.Support.ViewAttributesDialogAddon.DLL----------------------------------------Bentley.Hyd.Haestad Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.Haestad.dll----------------------------------------Haestad.Domain.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.StormSewer.DLL----------------------------------------Haestad.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewer.DLL----------------------------------------Haestad.StormSewerProduct Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewerProduct.DLL----------------------------------------Haestad.Support.NumericalMethods Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.NumericalMethods.DLL----------------------------------------Bentley.Hyd.Haestad.ProductUpdate Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Bentley.Hyd.Haestad.ProductUpdate.dll----------------------------------------DevExpress.Charts.v9.1.Core Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Charts.v9.1.Core.dll----------------------------------------DevExpress.Data.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Data.v9.1.dll----------------------------------------DevExpress.Utils.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.Utils.v9.1.dll----------------------------------------Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------DevExpress.XtraBars.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraBars.v9.1.dll----------------------------------------DevExpress.XtraEditors.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraEditors.v9.1.DLL----------------------------------------DevExpress.XtraCharts.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraCharts.v9.1.dll----------------------------------------System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------DevExpress.XtraNavBar.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraNavBar.v9.1.dll----------------------------------------DevExpress.XtraPivotGrid.v9.1.Core Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPivotGrid.v9.1.Core.dll----------------------------------------DevExpress.XtraPivotGrid.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPivotGrid.v9.1.dll----------------------------------------DevExpress.XtraPrinting.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraPrinting.v9.1.dll----------------------------------------DevExpress.XtraTreeList.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraTreeList.v9.1.DLL----------------------------------------DevExpress.XtraRichEdit.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraRichEdit.v9.1.DLL----------------------------------------DevExpress.XtraReports.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraReports.v9.1.dll----------------------------------------DevExpress.XtraVerticalGrid.v9.1 Assembly Version: 9.1.4.0 Win32 Version: 9.1.4.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DevExpress.XtraVerticalGrid.v9.1.DLL----------------------------------------DWNetworkParser Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/DWNetworkParser.dll----------------------------------------Haestad.Calculations.Dynamic Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Dynamic.dll----------------------------------------Haestad.Hydraulics Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Hydraulics.DLL----------------------------------------Haestad.Domain.ModelingObjects.Dynamic Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.Dynamic.DLL----------------------------------------Haestad.Domain.ModelingObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.DLL----------------------------------------Haestad.Calculations.Dynamic.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Dynamic.Domain.dll----------------------------------------Haestad.Calculations.StormSewer.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.Domain.DLL----------------------------------------Haestad.Calculations.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.DLL----------------------------------------Haestad.Calculations.Scada.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Scada.Domain.DLL----------------------------------------Haestad.Calculations.PondPack.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.OutputReader.DLL----------------------------------------Haestad.Calculations.Scada.ScadaReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Scada.ScadaReader.DLL----------------------------------------Haestad.Calculations.GravityDerived Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GravityDerived.dll----------------------------------------Haestad.Calculations.GVFOutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GVFOutputReader.dll----------------------------------------Haestad.Calculations.StormSewer.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormSewer.OutputReader.DLL----------------------------------------Haestad.Calculations.GVFSolver Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.GVFSolver.dll----------------------------------------Haestad.Calculations.HHSolver.DataObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.dll----------------------------------------Haestad.Calculations.HHSolver.DataObjects.VB Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.DataObjects.VB.DLL----------------------------------------Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------Haestad.Calculations.HHSolver Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HHSolver.dll----------------------------------------Haestad.Calculations.HydrologyHydraulics Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.HydrologyHydraulics.dll----------------------------------------Haestad.Calculations.PondPack.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.Domain.DLL----------------------------------------Haestad.Calculations.PondPack Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.PondPack.DLL----------------------------------------Haestad.HydrologyHydraulics Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.HydrologyHydraulics.DLL----------------------------------------Haestad.Calculations.Pressure Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.dll----------------------------------------Haestad.Calculations.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Support.DLL----------------------------------------Haestad.Calculations.Pressure.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.Domain.dll----------------------------------------Haestad.Domain.ModelingObjects.Water Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.Water.DLL----------------------------------------Haestad.Calculations.Pressure.FlushingResultsReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.FlushingResultsReader.dll----------------------------------------Haestad.Calculations.Pressure.MSX Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.MSX.dll----------------------------------------Haestad.Calculations.Pressure.ResultsReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.Pressure.ResultsReader.dll----------------------------------------Haestad.Calculations.SewerCAD Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.dll----------------------------------------Haestad.Calculations.SewerCAD.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.Domain.dll----------------------------------------Haestad.Calculations.SWMM5.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.Domain.DLL----------------------------------------Haestad.Calculations.SewerCAD.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SewerCAD.OutputReader.dll----------------------------------------Haestad.Calculations.StormCAD Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormCAD.dll----------------------------------------Haestad.Calculations.StormCAD.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormCAD.Domain.dll----------------------------------------Haestad.Calculations.StormDerivedEngine Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.StormDerivedEngine.dll----------------------------------------Haestad.Calculations.SWMM5 Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.dll----------------------------------------Haestad.Calculations.SWMM5.OutputReader Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Calculations.SWMM5.OutputReader.dll----------------------------------------Haestad.CanvasLibrary.Drivers.GDI Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Drivers.GDI.dll----------------------------------------Haestad.CanvasLibrary.Framework Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Framework.DLL----------------------------------------Haestad.CanvasLibrary.Framework.Windows.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.CanvasLibrary.Framework.Windows.Forms.dll----------------------------------------Haestad.Domain.AceDaoInterop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.AceDaoInterop.dll----------------------------------------Haestad.Domain.DaoInterop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DaoInterop.dll----------------------------------------Haestad.Domain.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.dll----------------------------------------Haestad.Domain.DataExchange.IModel Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.dll----------------------------------------Haestad.Domain.DataExchange.IModel.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.Support.DLL----------------------------------------Haestad.Domain.DataExchange.IModel.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModel.Forms.dll----------------------------------------Haestad.Domain.DataExchange.IModelPlugIn Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataExchange.IModelPlugIn.dll----------------------------------------Haestad.Domain.DataObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataObjects.dll----------------------------------------Haestad.Domain.DataObjects.Water Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.DataObjects.Water.dll----------------------------------------Haestad.Domain.LibraryObjects Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.LibraryObjects.dll----------------------------------------Haestad.Domain.LibraryObjects.Install Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.LibraryObjects.Install.dll----------------------------------------System.Configuration.Install Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration.Install/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll----------------------------------------Haestad.Domain.ModelingObjects.PondPack Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.ModelingObjects.PondPack.dll----------------------------------------Haestad.Domain.SUE Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Domain.SUE.dll----------------------------------------Haestad.Drawing Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Drawing.DLL----------------------------------------Haestad.Framework.Windows.Forms.XtraReports Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.XtraReports.DLL----------------------------------------Haestad.Framework.Windows.Forms.Reporting Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Reporting.DLL----------------------------------------Haestad.ProjectWiseFacade Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ProjectWiseFacade.DLL----------------------------------------Haestad.GraphicsLibrary.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.Support.DLL----------------------------------------Haestad.DrawingStorage Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.DrawingStorage.dll----------------------------------------Haestad.DWNetworkParserBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.DWNetworkParserBuilder.dll----------------------------------------Haestad.Dynamic.DataExchange.CivilStorm Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Dynamic.DataExchange.CivilStorm.dll----------------------------------------Haestad.Schema.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Schema.DataExchange.DLL----------------------------------------Haestad.FileParser Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.FileParser.dll----------------------------------------Haestad.Framework.Windows.Forms.Divil Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Divil.dll----------------------------------------Haestad.Framework.Windows.Forms.Steema Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Steema.dll----------------------------------------Haestad.Framework.Windows.Forms.Syncfusion Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Framework.Windows.Forms.Syncfusion.dll----------------------------------------Haestad.GeoPAK Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GeoPAK.dll----------------------------------------Haestad.GraphicsFileLibrary.RasterFileLibrary Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsFileLibrary.RasterFileLibrary.dll----------------------------------------Haestad.GraphicsFileLibrary.VectorFileLibrary Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsFileLibrary.VectorFileLibrary.dll----------------------------------------Haestad.Shapefile Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Shapefile.DLL----------------------------------------Haestad.GraphicsLibrary.GDI Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.GDI.dll----------------------------------------Haestad.GraphicsLibrary.GDI.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.GDI.Support.dll----------------------------------------Haestad.GraphicsLibrary.OpenGL Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.GraphicsLibrary.OpenGL.dll----------------------------------------Haestad.HydraulicReviewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.HydraulicReviewer.dll----------------------------------------Haestad.InRoads Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.InRoads.dll----------------------------------------Haestad.LicenseAdministrator.Library Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LicenseAdministrator.Library.dll----------------------------------------Haestad.LoadBuilder.Calculations Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.dll----------------------------------------Haestad.LoadBuilder.Calculations.Sewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.Sewer.dll----------------------------------------Haestad.LoadBuilder.Calculations.SewerCAD Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.SewerCAD.dll----------------------------------------Haestad.LoadBuilder.Calculations.SewerGEMS Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Calculations.SewerGEMS.dll----------------------------------------Haestad.LoadBuilder.Data Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.Data.dll----------------------------------------Haestad.LoadBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.dll----------------------------------------Haestad.LoadBuilder.StormSewer Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.LoadBuilder.StormSewer.dll----------------------------------------Haestad.MicroStation.Support Assembly Version: 8.11.0.3 Win32 Version: CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MicroStation.Support.dll----------------------------------------Haestad.ModelBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.dll----------------------------------------Haestad.ModelBuilder.Support Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.Support.DLL----------------------------------------Haestad.ModelBuilder.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ModelBuilder.Forms.dll----------------------------------------Haestad.MX Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.MX.dll----------------------------------------Haestad.Network Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Network.dll----------------------------------------Haestad.NetworkBuilder Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.NetworkBuilder.dll----------------------------------------Haestad.SCADA.Domain.Application Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.Application.dll----------------------------------------Haestad.SCADA.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.DLL----------------------------------------Haestad.SCADA.Domain.HOPC Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.HOPC.dll----------------------------------------Haestad.SCADA.Domain.OPC Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Domain.OPC.dll----------------------------------------OpcDaNet Assembly Version: 9.0.1.0 Win32 Version: 9.0.1.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/OpcDaNet.DLL----------------------------------------Haestad.SCADA.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SCADA.Forms.dll----------------------------------------Haestad.ScenarioComparison Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ScenarioComparison.dll----------------------------------------Haestad.ScenarioComparison.Domain Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ScenarioComparison.Domain.dll----------------------------------------Haestad.Sewer.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Sewer.DataExchange.dll----------------------------------------Haestad.Sewer.DataExchange.IModelPlugIn Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Sewer.DataExchange.IModelPlugIn.dll----------------------------------------Haestad.SQLite Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SQLite.dll----------------------------------------Haestad.SQLiteConverter.Core Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SQLiteConverter.Core.dll----------------------------------------Haestad.Storm.DataExchange Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Storm.DataExchange.dll----------------------------------------Haestad.Water.Forms Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Water.Forms.DLL----------------------------------------TeeChart Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/TeeChart.DLL----------------------------------------Haestad.StormSewer.SQLiteConverter Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.StormSewer.SQLiteConverter.dll----------------------------------------Haestad.Support.LandXML Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.LandXML.DLL----------------------------------------Haestad.Subsurface Assembly Version: 8.11.9.136 Win32 Version: 8.11.9.136 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Subsurface.dll----------------------------------------Haestad.SUE.CP.ContentManagement Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.ContentManagement.dll----------------------------------------Haestad.SUE.CP Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.dll----------------------------------------Haestad.SUE Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.DLL----------------------------------------Haestad.SUE.CP.Model.3.1 Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.Model.3.1.dll----------------------------------------Haestad.SUE.CP.Presentation Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SUE.CP.Presentation.dll----------------------------------------SandBar Assembly Version: 1.4.3.1 Win32 Version: 1.4.3.1 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/SandBar.DLL----------------------------------------Haestad.Support.Mixed Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Support.Mixed.dll----------------------------------------Haestad.SurfaceModeling.Interop Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.SurfaceModeling.Interop.dll----------------------------------------Haestad.TerrainExtractor Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.TerrainExtractor.dll----------------------------------------Haestad.ThiessenPolygon Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ThiessenPolygon.dll----------------------------------------Haestad.ThiessenPolygon.Engine Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.ThiessenPolygon.Engine.dll----------------------------------------Haestad.UserDataExtensions Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.UserDataExtensions.dll----------------------------------------Haestad.Water.DataExchange.Controls Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Haestad.Water.DataExchange.Controls.dll----------------------------------------hmimsdascnet Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/hmimsdascnet.dll----------------------------------------IModelEngineAddIn Assembly Version: 1.0.0.0 Win32 Version: 08.11.07.63 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/IModelEngineAddIn.dll----------------------------------------Ionic.Zip Assembly Version: 1.9.1.8 Win32 Version: 1.9.1.8 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Ionic.Zip.dll----------------------------------------Microsoft.Data.ConnectionUI.Dialog Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Microsoft.Data.ConnectionUI.Dialog.dll----------------------------------------Microsoft.Data.ConnectionUI Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Microsoft.Data.ConnectionUI.DLL----------------------------------------MoreLinq Assembly Version: 1.1.17511.0 Win32 Version: 1.1.17511.618 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/MoreLinq.dll----------------------------------------OpcHDAWrapper Assembly Version: 6.0.0.0 Win32 Version: 6.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/OpcHDAWrapper.dll----------------------------------------SandDock Assembly Version: 3.0.6.1 Win32 Version: 3.0.6.1 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/SandDock.dll----------------------------------------TeeChart.Languages Assembly Version: 8.11.5.5 Win32 Version: 8.11.5.5 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/TeeChart.Languages.dll----------------------------------------Washington Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Washington.dll----------------------------------------Washington.MicroStation.CP Assembly Version: 8.11.0.3 Win32 Version: 8.11.0.3 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/Subsurface/Washington.MicroStation.CP.dll----------------------------------------Bentley.MicroStation.Templates Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.Templates.DLL----------------------------------------Bentley.MicroStation.Templates.Support.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.MicroStation.Templates.Support.resources.DLL----------------------------------------Bentley.DTM.ElementTemplate Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.DTM.ElementTemplate.DLL----------------------------------------Bentley.DTM.Element.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DTM.Element.resources.DLL----------------------------------------Bentley.MicroStation.GeoCoord Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.GeoCoord.DLL----------------------------------------publishdgn Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/publishdgn.DLL----------------------------------------PublishDgn.Interfaces.Transformation Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/PublishDgn.Interfaces.Transformation.DLL----------------------------------------bentley.publish Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/bentley.publish.DLL----------------------------------------TransformationControls Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/TransformationControls.DLL----------------------------------------publishdgn.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/publishdgn.resources.DLL----------------------------------------Bentley.RSS Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RSS.DLL----------------------------------------GCSDialog Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/mdlsys/asneeded/GCSDialog.DLL----------------------------------------ustnQCInspector Assembly Version: 2015.1.7.0 Win32 Version: 2015.1.7.0 CodeBase: file:///C:/FDOTSS4/apps/ustnQCInspector/uStnQCInspector.dll----------------------------------------PrintPrep Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.615 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PrintPreparation/bin/PrintPrep.dll----------------------------------------Bentley.ExtensionDiscovery Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL----------------------------------------Bentley.MicroStation.ECIntegration Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL----------------------------------------Bentley.GeorasterECPlugin Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.104 CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/DESCARTES/ASSEMBLIES/BENTLEY.GEORASTERECPLUGIN.dll----------------------------------------Bentley.BaseSQLPlugin Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.BaseSQLPlugin.DLL----------------------------------------Bentley.EC.SQLAdapter Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SQLAdapter.DLL----------------------------------------Bentley.EC.SchemaMappingSQLBuilder Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.EC.SchemaMappingSQLBuilder.DLL----------------------------------------Bentley.DgnECPlugin3 Assembly Version: 1.0.0.0 Win32 Version: 03.08.01.03 CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/POWERGEOPAK/CIVILPLATFORM/DESIGNSYNC/BENTLEY.DGNECPLUGIN3.dll----------------------------------------Bentley.ConfigurableECPlugin Assembly Version: 0.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/extensions/Bentley.ConfigurableECPlugin.DLL----------------------------------------Bentley.Descartes Assembly Version: 8.11.9.601 Win32 Version: 08.11.09.601 CodeBase: file:///C:/PROGRAM%20FILES%20(X86)/BENTLEY/POWERGEOPAK%20V8I%20(SELECTSERIES%204)/DESCARTES/ASSEMBLIES/BENTLEY.DESCARTES.dll----------------------------------------Bentley.RasterManager Assembly Version: 1.0.0.1 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RasterManager.DLL----------------------------------------Bentley.Civil.Geometry.Services.InRoads.3.1 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.845 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/RoadwayDesign/bin/Bentley.Civil.Geometry.Services.InRoads.3.1.dll----------------------------------------Bentley.DGNECPlugin.Common.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.DGNECPlugin.Common.resources.DLL----------------------------------------Bentley.MicroStation.WinForms.Docking Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL----------------------------------------Fdot.LDM Assembly Version: 1.1.10.0 Win32 Version: 1.1.10.0 CodeBase: file:///C:/FDOTSS4/apps/LDM/Fdot.LDM.dll----------------------------------------SyncXS Assembly Version: 1.0.10.0 Win32 Version: 01.00.10 CodeBase: file:///C:/FDOTSS4/apps/SyncXS/SyncXS.dll----------------------------------------Bentley.Civil.LandXml.3.0 Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.394 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/DTMLink/Bentley.Civil.LandXml.3.0.dll----------------------------------------Bentley.ECSystem.2.0.resources Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.ECSystem.2.0.resources.DLL----------------------------------------Bentley.Windowing.Win32 Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Windowing.Win32.DLL----------------------------------------Bentley.Windowing.resources Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.Windowing.resources.DLL----------------------------------------bentley.designexplorer.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/bentley.designexplorer.resources.DLL----------------------------------------bentley.designexplorer.elementexplorer.markupsvhandler Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/bentley.designexplorer.elementexplorer.markupsvhandler.DLL----------------------------------------Bentley.Internal.RealDwg Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.Internal.RealDwg.DLL----------------------------------------bentley.designexplorer.elementexplorer.resources Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/bentley.designexplorer.elementexplorer.resources.DLL----------------------------------------Bentley.TaskNavigation Assembly Version: 2.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.TaskNavigation.DLL----------------------------------------Bentley.TaskNavigation.resources Assembly Version: 2.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.TaskNavigation.resources.DLL----------------------------------------Bentley.EC.Controls.2.0.resources Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.EC.Controls.2.0.resources.DLL----------------------------------------CustomMarshalers Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.9136 (WinRelRS6.050727-9100) CodeBase: file:///C:/WINDOWS/assembly/GAC_32/CustomMarshalers/2.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll----------------------------------------Bentley.RSS.Common Assembly Version: 1.0.0.0 Win32 Version: 08.11.09.714 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Bentley.RSS.Common.DLL----------------------------------------Bentley.Geometry.Convert.2.0 Assembly Version: 2.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Geometry.Convert.2.0.DLL----------------------------------------Fdot.Features Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/FDOTSS4/mdlapps/Fdot.Features.dll----------------------------------------System.Xml.Linq Assembly Version: 3.5.0.0 Win32 Version: 3.5.30729.9135 built by: WinRelRS6 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml.Linq/3.5.0.0__b77a5c561934e089/System.Xml.Linq.dll----------------------------------------Bentley.Units Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/ECFramework/Bentley.Units.DLL----------------------------------------Bentley.UI.resources Assembly Version: 1.0.0.0 Win32 Version: 08.33.01.03 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/en/Bentley.UI.resources.DLL----------------------------------------Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0 Assembly Version: 1.0.0.0 Win32 Version: 01.00.00.02 CodeBase: file:///C:/Program%20Files%20(x86)/Bentley/PowerGEOPAK%20V8i%20(SELECTSeries%204)/PowerGEOPAK/Assemblies/Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0.DLL----------------------------------------
************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /></configuration>
When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
