This was a fresh install on a new machine. FDOT SS10 with GEOPAK crashes with these errors upon launch, FDOT SS10 works fine with out GEOPAK.Ran the Dot Net Fix tool from Microsoft.
We started with MS V8i 08.11.09.916, then installed GEOPAK Suite 08.11.09.918, then installed FDOT SS10 MR3 10.03. Microstation runs without issues, launching FDOT SS10 without GEOPAK also runs fine without issue. The errors only come up when running FDOT SS10 MR3 with GEOPAK.
I have uninstalled all Bentley and FDOT software. I then installed the files for the SS4 installation. I am getting the same errors when trying to run FDOT SS4 with GEOPAK.
It Seems launching anything with GEOPAK is causing the crash, not just FDOT Software.
This problem is entirely GEOPAK.
This is happening with both SS4 and SS10 using the recommended versions for FDOT.
Have you tried running FDOT's Workspace Doctor? The reinstall may not have wiped out the prefs under the user folder C:\Users\semsli\AppData\Local\Bentley\{version}\{version#}\{folder}\prefs\
colliersengineering.com
Thank you for the response. We determined that GEOPAK was the problem. Not FDOT software. I wiped the machine clean and installed everything fresh and this resolved the issue.
