When I place labels using the place note with leader tool and using the text favorites the leader line is rotating based on the unrotated view.
I have looked into the other Bentley Communities and found many people having the same issue but no solutions other than this is just the way it is now.
Anyone encountered this and found a way to have the leader line be inline with the text rather than true north?
Thank you,
Dennis
Unfortunately, you are correct that this is a known issue. FDOT has reported it to Bentley as well.
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
Has this issue been resolved by Bentley since it was last reported to them. We have been running into this issue as well.
Yes, also would like to know the status. Additionally, how do we achieve the delimiter line between text as we did with the Geopak Labeler?
OpenRoads Designer Accredited
colliersengineering.com
As far as I know, this hasn't been resolved in 10.09 either, so we're stuck with it for a while. As for the delimiter, I haven't been able to find a way to include this in the dynamic labels (notes work fine) through Text Favorites. I haven't given the Cell option a chance yet, but that might work.
Eddie Giese, PEProduction Manager (licensed in FL & PA)
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
I've utilized the underline/overline text options with the text favorites and unchecked the in-line leader. That's probably about as close as we will get to the old geopak labels.
