I am having difficulty getting shp files to show up in my plan sheets. It shows up in the default model but not the sheets. I have tried it two ways with the same result. I have a dgn with the shape files referenced into it. I then referenced this into my plan.dgn file. Live nesting is on with a depth of 1. I have tried changing depth as well. I also tried referencing the shp files directly into the plan.dgn file. If anyone has any experience with this issue or any ideas, please let me know. This is what message center says. It appears to be the same issue for both tactics:
No problem! You essentially eliminated the nesting problem I mentioned by doing that. Glad to hear you got it worked out!
Eddie Giese, PEProduction Manager (licensed in FL & PA)
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
