OpenRoads Earthwork-Cut and Fill Volumes not displaying
Trying to compute earthwork quantities for cross section sheets and following the posted webinars. When I try to run the create Cut Fill Volumes under Civil analysis, it appears the program computes the data however the blue and red tringles never appear in either view. Also when I generate the End Area Volumes report it only shows volumes for the last cross section. Any help would be greatly appreciated.
Blaine
  • Blaine,
    It would be helpful to provide some additional information such as pictures and/or the data so we can help you better.
    Ensure you've got the existing terrain referenced as well as the proposed model(s). It makes sense that the End Area Volume Report is not returning values, as that reads "slices" of the cut/fill volumes at the specified interval.
    Eddie Giese, PE
    Production Manager (licensed in FL & PA)
    Patel, Greene & Associates, LLC
    PowerGEOPAK V8i SS10 (08.11.09.918)
    OpenRoads Designer 2021 R2 (10.10.21.4)
    OpenRoads Designer 2020 R3 (10.9.0.91)
    ProjectWise Explorer CE 10.0.3.453
    LumenRT CE Update 14 (16.14.60.98)
