I am running of ORD. I am having trouble locating a panel that would be used for a street name commonly posted at unsignalized urban intersections comparable to the picture below. I am trying to add the panel that is named D3-1 in the MUTCD or comparable. I cannot seem to locate it. Has anyone encountered this issue or know the proper workflow for adding this panel to my assembly? Forgive me I just started using this app for the first time. I am adding a picture of the ORD Sign Assemblies Dialogue below as well.
Brian,
Have you tried looking in other Panel Class options to see if the sign panel is available? I think the D3-1 is available in the "Spec" class since it is a special sign that would require GuideSign to generate (dependent on length of road name).
Eddie Giese, PEProduction Manager | Senior Roadway Engineer | AssociateLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2022 R3 (10.12.2.4)ProjectWise Explorer CE 10.0.3.453OpenRoads Conceptstation CONNECT Edition (10.0.16.84)LumenRT Pro CONNECT Edition (16.17.60.73)
Thank you Eddie. Your advice was a big help.
