Is there a trick to moving sheets up and down in the Sheet Index? It appears that ORD will only allow new sheets to be added to the bottom of the index. Is anyone else running into this issue?
Blaine
Blaine,
Yes, unfortunately, that is a known issue at least through 10.09 (haven't tested 10.10 with this yet). There are some workarounds but none of them are particularly enjoyable, IMO. One that I have used and heard others using is to drag the sheets out of the subfolders into the root folder and then drag them back in, in the order you wish.
Eddie Giese, PEProduction Manager (licensed in FL & PA)
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
I used Sheet Index on the last job I just did and I will NOT be using it again. Its a complete waste of time. You can get it all set up, but as everyone knows, moving sheets around is very time consuming. Also, as the Index gets larger, it takes longer and longer to process new sheets and any changes you make.
Once you get that sheet Index set up, you still have to go open ever Sheet Model of every sheet to get the number to update anyway, which is also time consuming.
What I am doing on my current project is creating my Index in Excel, which I LDM into the Keysheet for my Roadway Index anyway. Then I go into each dgn with Sheets, open up the Models dialogue, enter the sheet numbers in the Sheet Number column, and then open ever sheet model. Its definitely not the best thing ever, but much easier than dealing with Sheet Index.
Also, reach out to FDOT and tell them how much you enjoy old Sheet Navigator and how much you would like them to bring it back!
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 3080 FTW3 Ultra | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
Power GEOPAK V8i Select Series 10 Version 08.11.09.918 | FDOT SS10 Version 01.04.01
ORD Version 10.10.21.04 | FDOT Connect Version 10.10.03
YouTube Page for ORD: https://www.youtube.com/channel/UC3S-94f7_yUJ-GMhMYPhInA
Man, oh man. I thought I was the only one having major issues with Sheet Index. Thanks for the tips Zachary, and I second your suggestion on FDOT bringing back the old Sheet Navigator. Don't get me wrong, it had it's on set of issues, but at least it wasn't so buggy.
Maybe I'm getting impatient as I grow older, but I don't think there's any excuse for an upgraded Microstation to lock up indefinitely while working in the background, at least not without something (a countdown timer at the very least?) telling us "Hey, I'm not locked up forever"! Sheet numbering and fields shouldn't be so difficult IMHO.
What I did on my most recent job has worked a little better. I still create that Index in Excel so I can keep track of everything. Its got a few more formulas in there that makes it easier to add and remove sheets, but its still just a guide.
I updated my pen table to turn off the Level TextShtNo, which is the level all the sheet numbers are on. Then, after I print, I just have Bluebeam (and im sure Adobe can do this too) add a footer on every sheet for the sheet number. I just adjust the footer so it fits in that box on every sheet.
This was way easier when i was working with my 650+ sheet plan set recently.
Still hoping for sheet navigator, but honestly, this method is pretty easy too.
Blaine, you can order them manually, however the catch is you can only move sheets down in the index, which can be frustrating on large plan sets. Hope this helps!
