In SS10, we had a VBA that would open the little tool box with Place Cell Along in it. I have not been able to locate this same tool in ORD. Has anyone had any luck?
Not sure if this is what you refer to, but the closest tool I've been able to find to the Place Cell Group By Feature in SS10 is the FDOT Traffic Design tool.
Eddie Giese, PEProduction Manager (licensed in FL & PA)
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
This tool is what I need. Unfortunately I can't select the cell I need as there are no traffic control items in here. I am trying to place Channelizing Devices for TTC.
Thanks for the suggestion though, I had never actually taken a look at that tool!
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 3080 FTW3 Ultra | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
Power GEOPAK V8i Select Series 10 Version 08.11.09.918 | FDOT SS10 Version 01.04.01
ORD Version 10.10.21.04 | FDOT Connect Version 10.10.03
YouTube Page for ORD: https://www.youtube.com/channel/UC3S-94f7_yUJ-GMhMYPhInA
Definitely a good point. Would be nice to see that added by FDOT. That's what I used the tool for most (well, that and RPMs) in SS10.
An alternative method for the CDs would be to use the Construct Array tool to place along a path at your specified distance. I've used that with success in the past as well. You won't be able to offset a line/arc/complex chain with the tool, but you can make a separate element on Scratch/NonPlotting/ConstLines to serve as a placement guide.
Thats what I used it for to. You CAN place RPMS with the tool you mentioned as well as the Pavement Marking tool I believe. Ill check out the Array method as well.
Thanks!
