As stated in the subject upon trying to recut profile and cross section sheets all of the sheets were displaying as empty (except for the annotation) and I noticed that every new model (both the drawing models and the sheet models) created from those named boundaries have their references set to No Nesting. This was not happening earlier in the project for profile creation, and when it did happen to the cross sections, I had to create a new "cross section starter" file (I tried a new sheet seed but somehow even that didn't work) so I tried that same process on "plan/profile starter" but that did not work in this case. This issue is happening in cross sections again as well and I have attempted various seed files (original FDOT and my new custom ones) but all are coming in with No Nesting. I have tried remaking new named boundaries but that did not change anything. Is this a known issue with a solution?
Thank you
found this - but it seems you are encountering the opposite:
https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/207187/ord-drawing-production---nesting-depth-value-99/689897#689897
Timothy Hickman
Main: 877 627 3772|
What version are you using?
It has been our experience that the sheet creation process completely ignores the nesting depths set in the drawing & sheet seed files anyway. We've resorted to a custom VBA to set the depths properly following the sheet creation.
Eddie Giese, PEProduction Manager (licensed in FL & PA)
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
