I've never really had an error like this before while using SS10; however, I recently got a new computer and that's when this problem started. When I try to draw elements or text, the elements partially disappear while I'm drawing them. When I click to place, I can see the graphics just fine. Zooming in and out will flicker the graphics while mid placement. Has anyone run into this issue previously? I can fix the issue temporarily by running workspace doctor and resetting settings; however it becomes corrupt again within minutes.
In the image below my line should be going from the top of pavement to the middle of the pipe, but you can see it's only partially visible. I assume there is some graphical setting that needs to be tweaked. Not sure if this can be handled with a configuration variable or if it's a known driver issue?
Has anyone else had this issue before?
This fixed the issue for me thank you!
For those with Nvidia cards having this issue here is what I did:
I'm not sure if the second setting is required or not but I did both at once and it worked fine.
setting it either way would work - but it looks like tweaking the NVIDIA card worked
Timothy Hickman
Main: 877 627 3772|
Hello Nicholas,
We've seen this issue arise just last week with a new (for us) Lenovo ThinkPad P1 laptop (NVIDIA T1200 Graphics Card). After trying a number of things, it seems that we needed to add the application (Power GEOPAK V8i (SELECTseries 10), in our case to the Graphics performance preference settings (search for Graphics settings in the Settings search field). Notice the High performance setting for the added Desktop app. You can set this at the time of adding the program.
This is separate from the NVIDIA Control Panel (Manage 3D Settings) area, which we did not change (in our case) as the issue is not 3D-related.
ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
ProjectWise Drive, Version 2022.1.328
OpenRoads Designer CONNECT Edition, Version 10.09.00.91
OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
This is great info, thank you for sharing!
thanks for sharing. I'll be on the lookout for this.
