Is there a tool similar to the Design File Cleanup tool in Connect 10.10? It was a great tool in SS10 to select duplicate elements. I can't figure out where it is.
Yep! Just use the key-in "mdl load cleanup" and that will invoke the dialog.
Eddie Giese, PEProduction Manager (licensed in FL & PA)
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
