Why do elements like signs and RPMs belong in groups? Is there a way to prevent this from happening when placing elements?
Pavement markings do too. Sometimes if you delete something, other things in the plans delete too but if you are zoomed in you would never know it happened.
ORD V. 10.10.01.003
ConnectionClient V 11.00.04.15
FDOT V. 10.10.00.01
uncheck graphic group to avoid this.
Just out of curiosity, how could this happen? Is it default in ORD or does the signing or pavement markings program do this? I never used it in SS10, so I had no clue to even check this.
not sure but i think when you make a new seed file from beginning it comes checked on.
It seems that the seed file has it toggled on, so any new file you make it will be on by default.
You may be able to go into your seed file and toggle it off and save settings, but then you would have to do that for each user and every time you get a new update, you would have to do it again if they replace it in the update...
