User/File Settings
Has anyone had any issues with view settings of a file? Everything seems to be so tiny in my files (nodes/text/colors are hard to see) (see the attached example of a temp horizontal dimension in the cross section view). Is there a setting i can tweak with so that things are easier to see. Thank you!
