I was wondering what item would Gravity Wall fall under when generating automated quantities from a 3D model. I'm not seeing it under the Roadway Quantities library in the PayItemDB.
Kristina,
I am using FDOT Connect 10.11 right now, but I do not see the pay item 0400 0 11 in the Asset Manager Lookup spreadsheet located here:
C:\FDOTConnect10.11\Organization-Civil\FDOT\Asset Manager\Asset Management Lookup.xlsxI actually made a custom 0400 0 11 line item in the library. It does work as in you can attach the item to the shape in 3D; however, the Summary of Walls doesn't know to pull that item into it when run. Perhaps the Summary of Walls is intended to be filled out manually.
I had reached out to FDOT CADD support (Kandi Daffin), she mentioned that Summary of Walls is not automated. So the gravity wall quantity needs to be done manually.
Thank you for sharing. I will have a Summary of Walls on one of my projects now so we will fill the information manually.
Hey Nick and Kristina, anything that is in BOLD FONT the tool will pick it up, no matter the source of the item. Anything that is not BOLD FONT is expected to be filled manually. See image attached.
Hi there! Just circling back to this! I'm in the midst of putting together my Gravity wall quantity. My model is created via corridors. So, the gravity wall shape is connected through the corridor. Is there a way to get separate wall quantities?
