Is it possible to insert a hyperlink to a Microstation file and give it a certain display, like "Link to Sharepoint"? I also want it to migrate into the .pdf plot of the file.
Yes, see the FDOT Roadway KeySheet in the lower left hand corner for an example. the link becomes active when plotted in a PDF format.
I got it to work Bob, but does it have to be a text string on a single line? The URL is extremely long and would either stretch across the page or have to be so tiny you could hardly see it.
Patrick Serpas, DraftsmanImperial Polk County, FL
Power GEOPAK V8i (SS 2) v.08.11.07.615Descartes V8i v. 08.11.09.432GuidSIGN v. 6.0.0Cadpilot UI 01.07.00 - build 2013.01.22.1042
Windows 7, Intel i5-2400 CPU @ 3.10 GHz, 4 GB RAM
Just go to TinyURL.com, and enter your link. For instance, here is this webpage condensed into a smaller URL: http://tinyurl.com/b83b48e
