Is there a way to change the path that Microstation loads the funckey.mnu from when starting the program? For example, instead of having the default funckey.mnu load, I want to load my custom one each time without having to delete the one that is installed in the default location, where ever that is.
Typically, I don't have rights to any program file on this computer, so I would like to point the file path to a convenient locations, such as my documents.
Pat
