I am upgrading a user from ustat/gpk to pgpk. I an uninstalling everything Bentley and then installing pgpk. After the Bentley install is finished, is it necessary for the FDOT Workstation to be reinstalled in order for all the hooks to reengage? Will it suffice to merely do a repair install of the existing FDOT Workstation install? Programs & Freatures shows it as v1.0.0. Will a repair install revert the current 1.2.1 back to 1.0.0 thus nullifying the MR2 update and hotfix? If so, will the bar menu and version.txt reflect that it indeed has reverted back? Or will I be deceived into thinking I'm still on 1.2.1? If the MR2 is retained, will the hotfix also be retained?
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
