Best Practice - Change a workstation from FDOTSSR MR12 Client to FDOTSS4 Workstation
Due to performance issues I want to uninstall the client from my desktop and start using a stand-alone workstation.  I did call the ECSO and was told to read installation instructions carefully, remove old files left behind, etc.  My question is: Are there any other things I need to be aware of, other than carefully following the installation manual and clearing out the C:\FDOTSS4 folder before the new install?
FDOTSS4 MR12 (Version:01.12.00)
Power GEOPAK V8i (SELECTseries 4)
 Windows 10 Pro for Workstations
  1. 10.0.18363 Build 18363
  • Patrick,
    The process you describe above is sound and should get you where you're going.  Here are some additional ideas:
    1. Uninstall the FDOTSS4 client.
    2. Be sure you are running the .878 or .904 version of Power GEOPAK Select Series 4
    3. Delete the FDOTSS4 desktop folder and C:\FDOTSS4\ folder if they were not removed by the uninstall.
    4. Install the FDOTSS4 MR12 workstation installation. There is also a QC fix available on our download page.
    5. Restart your machine.
    Some additional steps that shouldn't be necessary but might also be good to be aware of:
    1. Running Workspace Doctor with all options enabled after doing a fresh install of the FDOTSS4 software is not a bad idea. Can't hurt and might clear out leftover temp data.
    2. Right clicking on the FDOTSS4 launch icon and selecting "Run As Administrator" for the very first launch of a brand new install is also a good idea. Not necessarily critical, but if you've found that you are prone to VBA errors, this might help prevent that.
    These are absolutely all the things I can think to mention. If you do run into any problems, please feel free to contact me.
    Thanks!
    Matt Sexton
    CADD Applications Support Coordinator
    Florida Department of Transportation
    Engineering/CADD Systems Office
    850-414-4840
    matt.sexton@dot.state.fl.us
    Answer Verified By: Polk Draftsman
