Is there a system variable I can set to reflect nested overrides using fdot openroads evironment. I have set the symbology overrides in my default view to reflect the way I want them to plot.
Its when I go back to either the model view or sheet view the levels do not reflect my overrides..
I also had this issue. I found that going to the reference in the Plan Model, opening the Presentation settings, and setting that to Level Overrides that will then be reflected in the Sheet Model.
HI Barry thanks for your reply. That was the answer I was looking for. I new to ORD. So I'm going through a learning curve.
