I just install the FDOTconnect after installing OpenRoads Designer CE. the "FDOTConnect to OpenRoads Designer" icon is missing. In addition, I have access to the FDOT workspace, but the "FDOT" tab is missing. Please help.
Hello Fenson,
Which version of OpenRoads Designer CONNECT Edition and FDOT Connect programs did you install? Incorrect or incompatible versions may be the cause for the missing FDOTConnect for OpenRoads Designer Desktop Shortcut. As for the missing "FDOT" tab: This could be the result of an incomplete installation of the FDOT Connect software.
If the correct (compatible) versions of OpenRoads Designer CONNECT Edition and FDOT Connect programs are installed, you may want to check:
ProjectWise Explorer CONNECT Edition, Version 10.00.03.453
ProjectWise Drive, Version 2022.1.328
OpenRoads Designer CONNECT Edition, Version 10.09.00.91
OpenRoads Designer CE 202 Release 2, Version 10.10.21.4
Power GEOPAK V8i (SELECTseries 10), Version 08.11.09.918
Thank you for your help.
Per FDOT Cadd Support, FDOTConnect 10.09.00.00 software is certified for use with OpenRoads Designer 10.09.00.91. If install with a latest ORD version FDOTConnect will not work.
Thank you
The latest version of OpenRoads Designer CONNECT Edition is 10.10.01.03 which is not compatible with the FDOT Connect 10.09.00.00 software. So, you will need to download and install the 10.09.00.91 version of OpenRoads Designer.
FDOT is working on a version of FDOT Connect that will be compatible with the 10.10.XX.XX version of OpenRoads Designer. Not sure when it will be released. However, I am hearing before the end of 2021.
