Has anyone experienced issues installing FDOT 10.10.03?
Installing as Server/Client, initial issues were that Worksets were not being found as specified. Found that additional step is required to edit WorkspaceSetup.cfg to resolve.
Additionally, after Workset issue resolved, receive .NET error upon opening file, which at this point, have not yet been able to resolve. This error appears to be related to FDOT app not being able to see workset location.
If you are editing the location of the worksets after the install there is 2 places you need to modify: the Windows System variable "FDOT_WORKSETS_10.10" AND the registry entry "FDOT_WORKSETS_10.10" located here: "Computer\HKEY_LOCAL_MACHINE\SOFTWARE\FDOT\FDOT_CONNECT_10.10". Easier to just set the location during the installation than changing it after the installation.
Thanks Mike, the variable and registry key have been confirmed with training backslashes. I have also tried the .NET security commands for 32 and 64 bit.
I'm not sure if it has anything to do with the issue I am seeing, but in the FileChecker config file in the server component of the configuration, it appears it's still utilizing V8i variables??
If you send me an email: matt.sexton@dot.state.fl.us, I can set up a Teams meeting for further troubleshooting. Let me know what time works best for you.
Matt SextonCADD Applications Support CoordinatorFlorida Department of TransportationEngineering/CADD Systems Office850-414-4840matt.sexton@dot.state.fl.us
I believe I've resolved this. It looks to be that in the Client install wizard, when copying in my paths for server and/or worksets, I did not have trailing "\"...
Answer Verified By: zrider
