I have installed the appropriate software in the order as specified, installed the FDOT2010 client. I can launch MicroStation from the FDOT2010 icon and opens to the MicroStation Manager. When I select the file to open into,MicroStation hangs for about 30-45 seconds then an error appears.
Attached is theexception log.
I have reinstalled all software and multiple times with the same results. MicroStation will open outside the Fdot environment.
Thanks in advance,
Chuck
I spoke with Jimmie and he seems to think it may be a .Net security issue. Go to the link below and give it a try.
communities.bentley.com/.../189241.aspx
Answer Verified By: cmeuser
Good to go.
Thank you kindly
