I have installed the appropriate software in the order as specified, installed the FDOT2010 client. I can launch MicroStation from the FDOT2010 icon and opens to the MicroStation Manager. When I select the file to open into,MicroStation hangs for about 30-45 seconds then an error appears.
Attached is theexception log.
I have reinstalled all software and multiple times with the same results. MicroStation will open outside the Fdot environment.
Thanks in advance,
Chuck
Good to go.
Thank you kindly
