If the correct size is missing from a panels size list or if you are dealing with Signs created by the GuidSIGN program you can add the missing size and square footage to the Draw Sign Panel Size List.
Special Sign Sizes are done by the following procedure:
Inch” x inch”, sq foot (30”x24”,5)
Note: There are other formats that are accepted in the size filed found in the GEOPAK Help file, however, the format in the steps above are standard for FDOT jobs. This format is consistent with the with other sign sizes placed with the Draw Sign Program.
