All levels are on, but I can't see the color fill?
Is it off globally? Change that drop down from View Display to Global Display.
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 3080 FTW3 Ultra | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
Patrick,
You may want to double check that within your Program Settings (wrench icon) your Display Options are set to Color. This will override level control as long as GuidSIGN is loaded, to my knowledge.
Good luck!
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
If the Fill View Attribute is turned off, turn it back on and see if that will work. I agree with Eddie about the Program Settings, however, it looks like all of the levels are displayed in the image. If this is the case, perhaps fill is turned off...
Answer Verified By: Polk County Draftsman
Bingo. Thanks Bradley.
Patrick, DraftsmanImperial Polk County, FL
Power GEOPAK V8i (SELECTseries 4)Version 08.11.09.878Cadpilot UI cadpilot.ui.01.07.00 - build.2013.01.22.1042
