I am attempting to create my XS sheets and having some issues. It started with the Create Cross Sections. I kept having to re-run my XS due to making changes to my model. So what I would do is delete the previous XS model, then run a new one. After several times needing to do this, when I would try to hit apply to create a new XS model, nothing would happen.
I then decided to create a new file and everything worked fine. Then the same sort of thing started happening with my Label Cross Sections. My Surface dropdown had nothing in it. Also, when I would go to Features - Annotate, my Cross Features window had nothing in it.
I then asked someone else in the office to open the file and everything was working just fine for them in the same file. At the same time they were checking that, I again tried creating a new file and was able to run my new XS model and then label my XS as well.
It seems like something is happening on my machine where if I run the XS too many times, it breaks the file and I can no longer use it to run XS. I already tried deleting my resource files, but if anyone has a solution, please let me know.
Also, is there a better way to update by XS model besides just deleting it and creating a new one? I know I could probably just run in the sections that changed, but I figured it was easier to make a new model since I hadnt done any labeling or anything with the previous run.
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 3080 FTW3 Ultra | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
That is what I have been doing, but for me, if i do that too many times, I can no longer run anything; new cross sections, labeling, etc. It just happened again in my newest file after I just got done doing Mike's method. Here are pictures of what is happening:
Cannot select anything in Surface drop-down:
Nothing in my Features ->Annotate -> Crossing Features:
Something weird is going on, because if I create a new file, this will all work just fine until I do it too many times and it messed up again.
