Existing and Proposed Drainage
I am trying to draw my existing drainage in my GKLNRD01 file so that it will show up in my XS. I know I can do a single offset of the existing pipe line from the DREXRD01 file, then apply a profile to it. The problem I have is I cannot find which feature I need to attach to the line to make it an existing 18" pipe for example. I am able to kind of trick it for now and apple the 18" sanitary sewer attribute to it and the pipe shows up when I run XS.
This issue is basically carrying over into the SUE for proposed drainage as well. I have no drainage features available when using SUE to place a node or lateral.
I have Drainage selected in my FDOT Configuration Menu, so I dont know if there is something else I need to activate in order to get these features to be available.
