I am getting an odd issue where when I remove or modify a Parametric Constraint on my Corridor, the whole Corridor turns to a construction element. Toggling F7 turns the corridor back on, along with all my construction elements. I am able to solve this by selecting all the elements and setting them to Primary, but every time I make a change to a Parametric Constraint, they go back to Construction.
This is happening with a file located on a remote server. When I open the same file locally, the issue does not occur. I just started testing this new Riverbed Mobile utility that does some caching of files, so perhaps that has something to do with it.
Anyone have an issue like this?
Some time the Active Element class get changed to Construction. in the design file.
To change it back ...
1. Right Click on the MicroStation tool bar and turn on the Element Class tools
2. Toggle the active class back to Primary
Vern
Answer Verified By: Vern Danforth
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 4090 FE | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
