I have a linear template that I would like to drop at 1 ft intervals. I changed CIVIL_DEFAULT_LINEAR_STROKING from 50 to 1 in the workspace configuration, saved the change, saved settings, closed SS10, and then reopened it and my template is still drawing at 50 ft intervals. Can someone please help with this? Thank you in advance.
Joe,
What Design Stage/Feature Definition have you selected for the Corridor? It could be that the multiplier is causing this issue?
Eddie Giese, PEProduction Manager | Senior Roadway EngineerLicensed in FL & PAACEC FDOTConnect Instructor on behalf of FDOT
Patel, Greene & Associates, LLC PowerGEOPAK V8i SS10 (08.11.09.918)OpenRoads Designer 2021 R2 (10.10.21.4)OpenRoads Designer 2020 R3 (10.9.0.91)ProjectWise Explorer CE 10.0.3.453LumenRT CE Update 14 (16.14.60.98)
You changed the default linear stroking for any new elements, not ones that have already been drawn. First, I would suggest a default linear stroking of 5 or 10'. Next go the line the linear template is built in and go into the properties of the line and change the linear stroking to 1. That will change just that line. Once you do that, the linear template should follow suit assuming you have the Final design stage set for that linear template.
Zachary Billings, P.E.
Senior Roadway Engineer (Licensed in FL and MI)
CONSOR Engineers, LLC
System Info:
Windows 11 | Intel Core i7-13700k | Nvidia RTX 3080 FTW3 Ultra | 32 GB of RAM | 2 TB Western Digital Black SN850x NVME
ORD Version 10.12.02.004 | FDOT Connect Version 10.12.01.00
YouTube Page for ORD: https://tinyurl.com/BillingsCADD
Answer Verified By: Joe Moslemian
Thank you this worked. I figured this option would be on the template handle.
Thanks for trying to help Eddie. This was not the issue in this instance.
