I am attempting to use the FDOT_Depths.xslx report in OpenRoads; however, I am receiving a kickback error:
Does anyone know how to get this report functioning in OpenRoads, or how to make a quick report to do generate the depth between template point names?
Thank you!
There are paths listed in the report. Are these correct? Do you have those folders and any files as seen in the error message? Sometimes the locations that a report expects must be modified if you do not use the default locations when setting up a workspace.
Are you using 10.10? There is a known issue in 10.10 where the reports were not working correctly due to being unintentionally being rolled back from the fixes in 10.9. You can wait for the upcoming release (which may be tomorrow) or if you need them sooner I can probably send you the fixed files.
I am okay to wait on the new release. Thank you John!
