Good morning All,
I'm having a problem getting the "Merge Cross Sections" tool to work correctly.
I have both existing and proposed cross sections cut and residing in their proper model views.
The merge tool recognizes the proposed cross sections source and I deselect the layers I don't want to be merged and then select "Process", but nothing gets copied over.
Any help would be greatly appreciated.
Using PowerGEOPAK / FDOT SS4
Good morning Brett,
Are you running the tool from within your existing cross section model? Also, what versions of PowerGeopak and FDOTSS4 are you using?
Chris Thorp
CADD Applications Support Coordinator
Office of Design / CADD
605 Suwannee St, Mail Station 69
Tallahassee, FL 32399-0450
Support Email: CADD.support@dot.state.fl.us
Hi Chris,
I figured out what I was doing wrong….I was “deleting duplicates” before merging.
I realized my order of processing was the problem…all is well now
Glad to hear you got it resolved. if you run into any other issues, feel free to contact the CADD Office directly, cadd.support@dot.state.fl.us
